Re: Stiff brake/clutch pedal on Farmall A
Posted by scotty on May 17, 2006 at 12:03:19 from (199.231.49.128):
In Reply to: Stiff brake/clutch pedal on Farmall A posted by Thomas Minter on May 17, 2006 at 11:13:24:
Hi Tom,
Yep, there are grease fittings down there. I believe there are even holes in the guard to allow access to them. You might try removing the guard for a closer inspection. If I recall the grease fitting is right in the pedal casting itself. When I was rebuilding my Super A the right brake pedal had a badly worn bore, which I removed and rebored and installed a bushing. After I did that I had to redrill the zerk tapped hole back out to get through the new bushing wall :")
scotty
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
