Re: Stiff brake/clutch pedal on Farmall A
Posted by Daniel H. on May 17, 2006 at 17:11:39 from (66.226.34.159):
In Reply to: Re: Stiff brake/clutch pedal on Farmall A posted by scotty on May 17, 2006 at 12:03:19:
I have an "A" right pedal and bracket that does NOT have the grease fitting. There is no provision for it in the casting. I got it at a salvage yard to use while I had the orignal one on my 100 bored out and bushed. I'm betting the early "A's" didn't have them. You might have to tear them down and have oillite bushings put in to solve the problem once and for all.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
