Re: Timing a 300 utillity
Posted by rick/Oasis ID on May 17, 2006 at 14:24:13 from (207.200.116.5):
In Reply to: Timing a 300 utillity posted by 300Randy on May 17, 2006 at 13:25:18:
If it's running and you want to set the timing you need a timing. If it's not running and you want to see if it's in time, you need to pull the #1 plug,cover the hole with your finger, bump it over until it blows your finger out ( you will feel the compression) look for the mark on the front pulley to line up with the timing mark( get it as close as you can ). now pull the dist cap and the rotor should point to the #1 post on the cap.
