Re: IHC 234 PTO Problem
Posted by JD Foreman on May 18, 2006 at 03:05:09 from (69.223.67.27):
In Reply to: IHC 234 PTO Problem posted by SDO on May 17, 2006 at 22:05:07:
I have a 404 and it had a similar problem about two months ago. I would investigate before running the PTO again. On mine, two pins and four bolts had broken that internally hold the PTO housing together. I couldn't even find a couple of the bolts so I think someone worked on it before but did a poor job. Removing the PTO was not too complicated. A manual helps but all you really do (on mine anyway) is remove four bolts and pull it straight out. But to get to it, you have to remove some of the 3-point hitch. Again, not too hard. Put something under the opening to catch hydraulic fluid. When you get inside, it should be obvious where the problem is. I used a tap to remove the pins and broken bolts. Then I made new pins from 3/8 shoulder bolts and put it all back together. The grinding came from an aluminum gear getting chewed up by the steel differential gear. Bad news. Mind wasn't too bad so I put it back in and it's running fine. The gear doesn't mesh, it simply interlocks, so a little wear shouldn't hurt. Don't wait too long to replace it though. I finished it in about four hours plus a trip to the store for bolts and hydraulic fluid. If your gasket tears on removal, you will need to order a new one, make one, or maybe use permatex. Hope this helps.
Home
| Forums
Today's Featured Article -
When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
