Re: SMTA - weak Hydraulic lift and noisy Live PTO
Posted by Walter in Ky on May 19, 2006 at 06:07:38 from (67.20.36.125):
In Reply to: SMTA - weak Hydraulic lift and noisy Live PTO posted by Walter in Ky on May 18, 2006 at 14:23:25:
Regarding the weight of the rake, we have a 1950 M with a belly pump, and it lifted this same rake fine last summer.
Could the issue be in the female hydraulic connectors on the tractor? The rake's connector fits new tractors (Deere) as well as the old M, (whose female connector has been changed to a universal type, per my Dad). If the SMTA female connectors were not letting enough fluid pass through, this could be the cause of the slow lifting, and apparent pressure build-up, causing the squealing. Perhaps I need to consider changing the female connectors? What do you think?
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
