Re: SMTA - weak Hydraulic lift and noisy Live PTO
Posted by Bob M on May 19, 2006 at 07:15:42 from (151.190.254.108):
In Reply to: Re: SMTA - weak Hydraulic lift and noisy Live PTO posted by Walter in Ky on May 19, 2006 at 06:07:38:
Hydraulic connector incompatibility could restrict flow to/from the rake cylinder.
Suggest removing the rod end pin from the rake cylinder then operating the cylinder unloaded. If it still moves slow and you get squealing from the tractor hydraulics, good chance the problem is restriction at the connectors.
