Re: 400 rear main seal
Posted by Kelly C on May 19, 2006 at 21:31:20 from (65.165.20.97):
In Reply to: 400 rear main seal posted by Jeh on May 19, 2006 at 15:26:00:
Do not trim the seals at all!!!! It will leak.
Basically all you do is soak the seal halves in oil for a bit. I left mine over night. Then install them in the seal retainer. I over hanged mine to cover the area where the 2 halves come together. Then install the top half of the retainer and gasket. After that put the bottom half up to the top half and use the cap screws ( shown by arrow in photo) to draw the 2 halves together. This compresses the seal around the shaft. Then tighten the 2 bottom bolts on the retainer.
