Re: Just checking in
Posted by farmer young on May 20, 2006 at 10:06:12 from (87.82.11.27):
In Reply to: Just checking in posted by Michael Soldan on May 13, 2006 at 06:48:15:
had triple heart bypass last september,before that went to doctors and he said if i am as fit as you at your age i will be very pleased.Two weeks later had a heart attack.blood pressure sky high,but still here ,beating undertaker,still above ground,but doing all the things the doc tells me to
