help oil leak
Posted by Bill Geer on May 21, 2006 at 06:01:24 from (216.157.203.35):
I have a 154 lo boy, I'am haveing a he-- of a time keeping a rear oil seal in it.
It seems like the retainer hole/surfsce is to big. The seal slips in real easy. Heck if I turn it over the seal will just about fall out.
I have tryed the blue sealer type goop with no luck.
What is the best way to fix this?
P.S.
Any body know where I can find a drive shaft with the pto pully on it.
Thamks Bill
