Re: Overrunning Pto Couplers
Posted by lee on May 21, 2006 at 07:25:57 from (12.6.154.110):
In Reply to: Overrunning Pto Couplers posted by MAGMAN on May 20, 2006 at 10:32:36:
If you've ever run an old tractor with bad brakes and bushog in an orchard you'll know a good over running coupling may literally keep you out of the trees or perhaps save you a radiator or two. An old Ford and I were promptly screwed right into a tree, busted radiator, numerous cuts and scratches and near lost an eye, before I found out my brother had welded his worn out over running coupling.
