Re: H STEERING SECTOR OIL
Posted by Roger46 on May 21, 2006 at 19:11:41 from (69.58.144.135):
In Reply to: H STEERING SECTOR OIL posted by James C. Newton on May 21, 2006 at 15:28:35:
If you have put new seals in the bottom of the vertical shaft and the steering wheel shaft you can use 90 weight oil, but is the seals have not been replaced since the tractor was new, you either need to change them or do as Danoh suggested and use grease. Roger
