SMTA hydraulic level check
Posted by sde on May 21, 2006 at 19:53:19 from (69.179.17.213):
Coworker bought a SMTA for $1600. How do we check hyd. fluid level. He will purchase manual for tractor, but we want to play now. Left side of control unit has an elbow, short nipple, Tee with a return line attached, and about an eight inch long pipe with a plug on the end. Fill it so the hytran is in the bottom of the elbow, Right?
#2 Used my 400 to pull his plow. Hytran came out one of the bolt holes on the axle housing, where the fender would mount. He said that the man he bought the SMTA from had filled his with silicone to prevent this from happening. Is this normal?
