Re: 140 Lift Helper Spring
Posted by Nat 2 on May 22, 2006 at 05:24:29 from (64.80.110.33):
In Reply to: 140 Lift Helper Spring posted by Avery on May 22, 2006 at 04:17:08:
Avery, I think you have the answers to all your questions right in front of your face:
1. The 140 with the helper spring lifts the disk okay.
2. The 140 that doesn't have the spring will lift the disk okay if you give it just a little push.
Logical conclusion: The helper spring gives it that little push it needs to lift the disk.
500 pounds is a lot to lift for these touch control units.
