Re: Leaking Sediment Bowl
Posted by RustyFarmall on May 22, 2006 at 06:44:49 from (207.32.13.237):
In Reply to: Leaking Sediment Bowl posted by DelMN on May 22, 2006 at 06:34:12:
The first thing you might try would be to tighten the packing nut a little bit. If that doesn't cure the problem you will be time and money ahead to just replace the entire sediment bowl assembly. Cost will be between $20 to $30 at your local Case-IH dealer, and the new one will be an exact duplicate of the original.
