Re: Farmall Super AV
Posted by Janicholson on May 22, 2006 at 07:52:43 from (199.17.6.175):
In Reply to: Farmall Super AV posted by Dereck Borders on May 22, 2006 at 07:19:55:
The engine serial is stamped into the engine on a raised area near #1 plug on the block. If the block has been replaced it will not have meaning. The casting codes for years are on this site and can help keep things "Kosher"
JimN
