Farmall Super AV
Posted by Dereck Borders on May 22, 2006 at 07:19:55 from (12.106.209.35):
I have a super AV that i am planning to restore. It has the C123 engine in it with the side hydraulic pump and a water pump. It did not have aserial number but I found on that should be a 1953 343XXX. The best I can tell the engine is the original but the serial number plate is missing. Also the hood seems a bit short for the distance from the grill to the gas tank. A friend said this was a hood from a distilate tractor. Would the serial number plate I have be acceptible for this tractor and if not does anyone know of a salvage plate I can get somewhere? Thanks,
Dereck B
