Re: Farmall A (4 position) switch getting too hot
Posted by Dave BN on May 22, 2006 at 19:05:14 from (64.12.116.65):
In Reply to: Farmall A (4 position) switch getting too hot posted by MACE on May 22, 2006 at 17:42:18:
When you put the cover on you are grounding the cover. You might have a bad switch. Try removing wires until the current draw stops, that should narrow down the problem. Or using an OHM meter, measure wach connector to ground. It might be something shorting to the case, so try using a jumper wire to ground the cover to the tractor and see if you get sparks/current draw. Dave.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
