Farmall A (4 position) switch getting too hot
Posted by MACE on May 22, 2006 at 17:42:18 from (66.23.230.57):
Any of you guys or gals had this happen?
I put an amp meter between the starter switch and the battery cable that goes to the light switch panel. Every time I put the instrument panel cover on the panel I see arcs and get a 1.9 amp draw every time. When I run the tractor like this with the meter in the same configuration to measure the amp draw, I see 7 amps and get an instrument panel that is quite hot with a positive rate of charge. Does this sound like I have a dead short somewhere in the switch? I had the generator and voltage regulator tested today and they both have a clean bill of health.
This 2 amp draw is killing my battery. What am I missing here?
MACE
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
