Re: Farmall A (4 position) switch getting too hot
Posted by Bob on May 22, 2006 at 19:57:53 from (64.21.249.40):
In Reply to: Farmall A (4 position) switch getting too hot posted by MACE on May 22, 2006 at 17:42:18:
Either the switch is defective, or you have "scrambled" the wires, and have a wire with battery voltage connected to the resistor used for the generator field (on tractors without a voltage regulator).
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
