Re: Super H H engine question...
Posted by Nat 2 on May 23, 2006 at 05:10:24 from (64.80.110.33):
In Reply to: Re: Super H H engine question... posted by Jugger on May 22, 2006 at 21:30:30:
Yes, it will bolt right in.
If you have, or want, live hydraulics, you either need to be rebuilding an engine out of a 1950 or newer H, or you need to use the timing gears and front cover for a 1950 or newer H or Super H.
It will still bolt right in with the old style front cover, though.
