Re: Farmall A (4 position) switch getting too hot
Posted by MACE on May 23, 2006 at 12:39:09 from (66.83.16.196):
In Reply to: Re: Farmall A (4 position) switch getting too hot posted by Janicholson on May 22, 2006 at 18:32:30:
Jim N,
I have double checked that the resistors or anything else hot or electrical does not touch. All I do is touch the amp cover to the case (I do not put it on all of the way) and I get a 2 amp draw) When I disconnect the battery wire from the back of the switch (the one that goes to the generator) then I know longer have a 2-amp draw. Upon taking the switch completely apart the other day, I found that it has some sort of mechanical cutout internally when it is turned completly counter clockwise. It is in the round part of the switch. Does anyone know what this part of the switch is used for. BTI. I installed a new regulator, generator, and wiring harness about a year ago.
Thanks,
MACE
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
