Re: Farmall A (4 position) switch getting too hot
Posted by Janicholson on May 22, 2006 at 18:32:30 from (66.173.50.31):
In Reply to: Farmall A (4 position) switch getting too hot posted by MACE on May 22, 2006 at 17:42:18:
There are resistors on the back of the switch to control the lights (and possibly the generator. These are probably touching the cover. They must not touch anything, they do get hot in use, but they are supposed to. It is shorting to the case. carefully bend them to miss the metal cover and it should be ok.
Let us know, JimN
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
