Re: Delco Starter Brushes
Posted by Tallperson on May 23, 2006 at 18:47:43 from (165.170.128.65):
In Reply to: Delco Starter Brushes posted by Brian Schmidt on May 23, 2006 at 10:38:58:
Brian my 53 SM got to where it would barely turn over, and as you said you needed to hold your mouth just right to catch it. I took the starter into Auto electric in Ft Collins Colorado. On the phone they assured me they had a good rebuilt in stock... NOT !!! But they did rebuild mine in 3 hours. The bushing at the back of the starter had failed and the rotor had cut a notch in the back plate heading for the ground. The upper brushes were not even contacting. It scared the hell out of me when I hit that rebuilt starter. The motor turned over so fast I thought the fan blast was going to pull it out of the shop by itself.. Good luck on geting yours going better. Tallperson
