Re: 806 voltage regulator
Posted by Bob on May 23, 2006 at 21:53:01 from (64.21.249.40):
In Reply to: Re: 806 voltage regulator posted by Rhino on May 22, 2006 at 18:18:42:
Rhino,
I finally got out the Blue Ribbon Service Manual tonight.
Simply put, #3 is connected to the side of the key switch that is only hot when the switch is "ON".
#4 is connected to the "idiot light", which is then connected to the same place as #3.
The resistor is connected BETWEEN #3 and #4.
