Re: Farmall M stuck in Road Gear
Posted by captaink on May 24, 2006 at 05:34:41 from (66.115.214.56):
In Reply to: Farmall M stuck in Road Gear posted by Hoosier Scott on May 24, 2006 at 04:45:59:
Just adding that if you happen to take the cover off the transmission, pull the rails down and check out the springs and balls. If they break, they don’t put enough tension on the balls and this makes it easier for a rail to keep moving right through neutral or move with the one adjacent to it (like when you shifted to 3rd the 5th rail moved along with it as I suspect) causing your problem. Common problem on the letter serried up to the 60 series.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
