300U clutch adjustment
Posted by 300Randy on May 24, 2006 at 05:37:46 from (208.44.151.58):
My 300U runs for more than 10-15 minutes now, must have been the points and condenser. Anyway I went to adjust the clutch and TA following the directions in a copy of the orginal manual. As I got into it I realized that all the adjustments have been maxed out. The one adjustment for the TA had me move the bracket that comes out of the side of tractor case counterclockwise and then adjust the linkage for 3/16 inch play. The linkage is as far as it will go ane I have about 1.0 inch of play. What do I have to replace to get back into spec? Is my clutch wore out? I know some of the linkage looks a little worn. How big of a job is it to rebuild the TA? Thanks
