Re: Plow Question Cant get it to BITE?
Posted by Mark on May 24, 2006 at 13:27:19 from (172.152.9.230):
In Reply to: Re: Plow Question Cant get it to BITE? posted by Andrew Z on May 24, 2006 at 13:11:34:
Andrew,
Plow points (shares) are a cheap investment and if you go to tractor supply or a temco, you should be able to save some money. Your friendly JD dealer can probably supply the points and rob you in the process...they do me everytime i am forced to shop there! But, worn out points are just that...go buy new ones and get your plowing done. Another factor is this time of year, the ground is getting dryer and harder and it gets worse. You'll be amazed at how your plow works with fresh points.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
