Re: Plow Question Cant get it to BITE?
Posted by Dellbertt on May 24, 2006 at 14:11:20 from (204.39.209.141):
In Reply to: Plow Question Cant get it to BITE? posted by Andrew Z on May 24, 2006 at 11:52:56:
I have welded homemade points to plows many times.
Any farm country welder should be able to add some 8" down points for you for next to nothing.
You can also buy used points from auctions or sellers.
But heres the real thing: an education costs money. Go buy a set of new points to see what they do and what they look like and then you will know what you are doing. AND if you are only doing a small garden these new points will last you many years.
ALSO- Make sure you have the plow hitch set right. The hitch/tongue adjustment is just as important as the depth setting. If you are using a three point drawbar and you do not have it low enough the plow will float.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
