Re: LB Engine
Posted by Steven@AZ on May 24, 2006 at 16:47:06 from (24.121.48.188):
In Reply to: LB Engine posted by Anderson on May 24, 2006 at 16:42:49:
I cannot tell you for sure, but every LA and LB engine I have seen had a throttle lever and the notches.
What is the serial number and data from the tag on this engine?
