Re: Finally got my 856
Posted by Colorado Curt on May 25, 2006 at 08:41:42 from (146.174.51.103):
In Reply to: Re: Finally got my 856 posted by Nebraska Cowman on May 25, 2006 at 08:30:21:
I don't run much in the winter and that cab sure cuts down the visibility. This 856 has the long axles and you can't see where they are at with that cab. We will be cutting grass hay here in a couple of weeks on the irrigated fields. Plan to put this girl on the baler and give the 560 a rest by running the rake.
