Re: Carb Adjustment on a B
Posted by old on May 25, 2006 at 13:37:31 from (4.245.2.2):
In Reply to: Carb Adjustment on a B posted by Doc T on May 25, 2006 at 13:28:48:
Fuel system needs to be checked and or the carb rebuilt. Pull the drain plug from the bottom of the carb and make sure you have a good steady flow of gas. If you don't then pull the line off the carb and make sure you have a good steady flow there. If you have a good steady flow from the drain plug then you have a clogged up carb and it needs to be rebuilt
