Farmall A Rear Wheels
Posted by Keith Cook on May 27, 2006 at 06:19:27 from (71.111.104.244):
My 1940 "A" has one cast iron rear wheel (casting 8529-D)and one that is stamped steel. This is the center part of the wheel that the rim mounts to. Is this correct?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
