Re: Farmall A Rear Wheels
Posted by Stan(PA) on May 27, 2006 at 06:54:52 from (24.52.125.65):
In Reply to: Farmall A Rear Wheels posted by Keith Cook on May 27, 2006 at 06:19:27:
Yes, it"s correct. The heavy cast wheel is a "counterweight" to counter the weight of the engine on the left. Cast wheel goes on the right (seat) side, and the cast wheel weight, plus driver weight, balances the tractor somewhat. Otherwise, engine side would be heavier, and cause tractor to tip easier.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
