Re: Control rod for two-way valve on Super H.
Posted by RustyFarmall on May 27, 2006 at 13:01:27 from (199.120.81.202):
In Reply to: Control rod for two-way valve on Super H. posted by Dennis Gauge on May 27, 2006 at 12:31:34:
I don't know all the details, but there is a seperate rod for the two way, and there is also a different rod support bracket, or maybe it is an attachment that bolts on to the existing rod support. Like I said, I don't know all the details, but I do know that I have seen two control rods on the tractors with the two way. Also, the main control rod will have a second catch on it, so you can lock the main rod into the engaged position.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
