Re: Update Shawn's SC
Posted by Keith-OR on May 28, 2006 at 09:59:29 from (207.200.116.5):
In Reply to: Re: Update Shawn's SC posted by Chris in Washington on May 28, 2006 at 08:02:09:
Chris, did you use the pattern I posted a while back for the puller? If so you should make the bar to push the pulley back on the crank. It is a lot easier using hydraulic jack to install, rather than beating pulley back on.
I don't think I have as before, where you located in Washington?
Keith & Shawn
