Re: Farmall A changing fan belt ?
Posted by Keith-OR on May 29, 2006 at 15:02:40 from (207.200.116.5):
In Reply to: Farmall A changing fan belt ? posted by Eben Merrill on May 29, 2006 at 14:29:50:
Eben, there is a 13/16 hex head right behind the back pulley, and on the backside of the bracket there is a nut that fits in between slots that is suppose to keep it (back nut) from turning. Better hope it is not rusted up like the engine we are working on. Had to remove the upper radiator spout and fan assembly from the engine to get at the back nut.HTH
Keith & Shawn
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
