Re: Differential Fluid in M
Posted by F-Dean on May 29, 2006 at 19:27:37 from (67.72.98.99):
In Reply to: Re: Differential Fluid in M posted by turbos10 on May 29, 2006 at 14:34:36:
When you go to buy the transmission oil as recommend here, see if they will take your old oil. Many places do. If they don't, buy elsewhere like Advance Auto.
