Re: Super C Was good!
Posted by ken church on May 30, 2006 at 03:02:42 from (205.188.116.133):
In Reply to: Super C Was good! posted by Andrew Z on May 29, 2006 at 17:49:59:
I would agree with what has bee said. I have had that happen to me on my 200 . the small gears inside the dist housing had got dry and stripped the teeth off. not hard to fix. like has been said remove number 1 spark plug ,crank over till you feel compression and stop there , look to see where your rotor is pointed,should be to number 1 cyl. had a neighbor that had same problem on a H. good luck. let us know what you find.
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
