Re: M burning points
Posted by John T on May 31, 2006 at 09:31:01 from (66.244.90.5):
In Reply to: Re: M burning points posted by Wicksfield on May 31, 2006 at 08:05:56:
Wick, if the points are deeply pitted on one side thats indicitave of a bad or weak but more often AN IMPROPER SIZE CONDENSOR to match up with your coil. I fear your coil isnt matched up as far as ohms (need around 3 ohms) and inductance with whatever condensor microfarads you have. The mis match where the condensor isnt the correct size to match the coils inductance and resistance causes premature point burn up. You need to get a regular IHC 12 volt (NOT for use with external ballast i.e. NO ballst required) coil and a condensor to match and that should solve the problem. I think that generic coil you claim is for use WITH OR WITHOUT a Ballast just isnt matching up with your condensor rating which is causing the points to burn up prematurely OR ELSE ITS SIMPLY WAY TOOOOOOO LOW OHMSSSSSS (should be near 3 ohms). For use "with or without" a ballast doesnt make good engineering sense to me for an old fashioned tractor points n condensor coil ignition system which ought to have sufficient total primary (coil + any external ballast) resistance to limit the current switched to around 4 amps or so MAX. REMEMBER EITHER excess current (over 4 maps) or a weak or mis sized condensor causes premature points burn up. I suspect that coils primary (between lil + and - terminals) is under 2 ohms and that excess current is frying the points, or else the condensor is wayyyyyyyy off size in microfarads to match up correctly with that coils inductance, hence no capacitive action, frying the points. The other alternative would be to use the old 6 volt coil and an external ballast of around 1.5 to 1.85 ohms (typical sizes on those ignitions) and the stock condensor from IHC CUZ IM NOT TRUSTING THAT SUPPOSED DUAL PURPOSE COIL ONE BIT LOL John T
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
