Re: Used tires 13-38
Posted by RustyFarmall on June 02, 2006 at 16:31:19 from (216.248.75.130):
In Reply to: Used tires 13-38 posted by SDE on June 02, 2006 at 14:43:22:
That 3 inch break could open up to be much larger when the tire is inflated, I would not use that one, and if you are going to the work of changing tires, you definately want to install tires that are good enough to last a long, long time. Some folks think that mismatched rear tires are O.K. as long as both of them are good. I disagree completely. The tractor will look and perform much better with a matched set of rear tires. When it comes time to sell the tractor, mismatched rear tires will discount the value considerably.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
