SA Coil and ground
Posted by Steve Santini on June 02, 2006 at 18:24:05 from (69.26.11.192):
To Bob M, Johnt, Gene-We talked about a coil and hotter plugs earlier. I have gotten both but my tractor is a negative ground-book says positive if I am reading it correctly. Can I leave the battery as neg. ground when I put new coil and plugs in? That is the way it has been since I got it, but has never run well yet. The battery is six volt in answer to earlier post. (three plugs in top, small battery)
Thanks Steve
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
