Re: SA Coil and ground
Posted by John T on June 02, 2006 at 20:10:57 from (66.244.90.5):
In Reply to: SA Coil and ground posted by Steve Santini on June 02, 2006 at 18:24:05:
Steve, 1) YES you can leave the tractor at Negative ground........... regardless if it were originally Positive, whatever turns your crank. 2) If you do, the coil should be wired with its lil - terminal to the distributor. 3) The coil will still spark even if wired backwards, but not as efficient, maybe run a tad hotter, and the spark isnt quite as good (may not run quite as well). 4) If it was changed from Pos to Neg the genny can still work fine PROVIDED it was properly polarized and assuming the Voltage Regulator is bi polar and works at either polarity as many are. 5) If a tractor with an ammeter has its polarity reversed, the ammeter leads need to be swapped or else it reads bass ackwards. Maybe yours was converted and all was done correctly (as posted) so it shouldnt be any problem now. If the ammeter is wired correct, if you turn lights or ignition on tractor not running, it should swing over to the - discharge direction, does yours??? 6) I recommend good quality wire core wires instead of the carbon core suppresor types and likewise, NON resistor hotter spark plugs. 7) Adjust the carbs float level,,,,,,,dont run the carb any over rich,,,,,,make sure the choke opens fully and theres no air cleaner or air inlet restrictions,,,,,,,use fresh clean water free 87 octane gas,,,,,,,,,,,keep the engine temp up higher,,,,,,,,,have fresh clean plugs and new or good proper adjusted points and a good conensor and you shouldnt have so many plug fouling problemns unless shes a bad oil burner and low on compression Nuff said, John T
Home
| Forums
Today's Featured Article -
Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t
... [Read Article]
Latest Ad:
2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
