Re: SA Coil
Posted by Nat 2 on June 02, 2006 at 20:54:40 from (24.93.8.168):
In Reply to: Re: SA Coil posted by Steve Santini on June 02, 2006 at 14:08:09:
ALL letter series Farmall tractors were POSITIVE ground from the factory. Over 50+ years, it could have been changed. With the stock system, all it took was swapping the battery cables, swapping the wires at the ammeter, swapping the wires on the coil and repolarizing the generator. All very simple tasks.
In reality, it doesn't matter which ground it is. Negative ground is better because everything that has a battery in it these days is negative ground. Less confusion when it comes time to jump start. There is no other technical advantage to one over the other... It was just how they did things in those days.
Maybe you have your coil wired up backwards?
