Re: SA Coil
Posted by Steve Santini on June 02, 2006 at 14:08:09 from (69.26.11.192):
In Reply to: Re: SA Coil posted by Bob M on June 02, 2006 at 12:54:54:
Bob M,
Good thoughts-but the battery is a smaller 'three holer'that is it has the three plastic fill holes down the center. All I can read on it besides serial # is Champion #1, 650 CCA. So I figured this has to be a six volt battery, yes? At least I have not seen a 12 V like this, but I could be wrong. Tried to look up Champ to check serial # and ended up at exide, not much help. Is it poss that could be a 12 V. battery? Also, my tractor is a neg. ground.,
No mag just dist. There is a very slight carbon deposit insde the dist cap where the rotor makes contact for each wire-this may not be signif. of anything.
Gene what did you mean about polarity? if you are on here. Bob that had two pretty good dents in it and looked pretty old. It did have a spart but seemed kind of puny and yellow. (I was out of sun when I checked it) Well I am off to get hotter plugs before I put the new coil in. Is this 51 SA supposed to be neg ground as standard, does anyone know? Thanks for any and all input. Steve
