Re: 6 volt or 12 volt
Posted by Brownie 45 on June 03, 2006 at 16:04:42 from (207.177.82.181):
In Reply to: 6 volt or 12 volt posted by bshannon on June 03, 2006 at 15:07:01:
If just the front bearing is siezed, & the rest of the unit is ok, you can replace the bearing on the alternator & save a few bucks.
