6 volt or 12 volt
Posted by bshannon on June 03, 2006 at 15:07:01 from (72.2.216.253):
Assuming I decide to go through with fixing up the old B, should I go with original 6 volt system, or repair cobbled up 12 volt it was converted to. (the alternator is locked up)
