Re: 6 volt or 12 volt
Posted by RustyFarmall on June 03, 2006 at 18:19:55 from (207.32.13.250):
In Reply to: 6 volt or 12 volt posted by bshannon on June 03, 2006 at 15:07:01:
You can buy a rebuilt alternator for less money than a refurbished generator, but if you can find a generator for a reasonable amount of money, that is the way I would go. The six volt generator system installed properly, all connections clean, bright, and tight, with 0 or 1 guage battery cables, will perform quite well and furnish more cranking power than you need. Plus, the generator will fit under the hood with no problem.
