Re: Super M stuck in 4th or 5th
Posted by Janicholson on June 03, 2006 at 21:42:00 from (66.173.50.76):
In Reply to: Super M stuck in 4th or 5th posted by jaybird2 on June 03, 2006 at 21:03:21:
I cannot think of one reason, or even a check, to avoid pulling the cover. If the tractor will not roll in (apparent) neutral, and it bogs when the clutch is released, it must be in the forks/rails, or gears. Every other possibility either allows the tractor to roll in neutral, or run in neutral with the clutch out. Even if it is a bearing, it will need the top off of the trans. Look through the belt pulley gearbox mount hole to see further into the system. Though not the best vantage point to see, it is much better than what is seen in the shifter hole. Best of luck, JimN
