Re: *!+11??*** (Translation=D...-thing
Posted by Janicholson on June 03, 2006 at 22:00:15 from (66.173.50.76):
In Reply to: *!+11??*** (Translation=D...-thing posted by Tom Windsor on June 03, 2006 at 20:27:53:
If you have the water jacket plate off of the side of the block, you can look in to see the condition of the cast iron part of the cylinders if they are not cracked/split or badly pitted from the water side, then getting the sleeves out without cracking them is important. I would cover the crankshaft with a piece of tin, then drill a 1/2" hole in the top of the piston (worst first, and 1/4" away from the edge on a side, not in alignment with the piston pin). Then I would use a single carbon rod in an arc welder to melt the piston on that side in short bursts of heat to melt only piston. This application of heat will likely free things up to allow the extraction of the piston. once the piston is out, welding four stripes of bead down each sleeve will shrink and free them enough (usually to get them moving with a puller puck and 3/4" reddy rod.) Good luck, I'm sure there will be more suggestions tomorrow. JimN
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
