CLARIFICATION
Posted by TOM WINDSOR on June 03, 2006 at 23:09:42 from (205.188.116.133):
In Reply to: Re: *!+11??*** (Translation=D...-thing posted by Janicholson on June 03, 2006 at 22:00:15:
I would cover the crankshaft with a piece of tin, PLEASE EXPLAIN THIS A LITTLE FURTHER SO I CAN UNDERSTAND THE PURPOSE HERE...EXACTLY WHERE TO PUT THE TIN?/ then drill a 1/2" hole in the top of the piston (worst first, and 1/4" away from the edge on a side, not in alignment with the piston pin). Then I would use a single carbon rod in an arc welder to melt the piston on that side in short bursts of heat to melt only piston.
HOW MUCH OF THE PISTON WOULD YOU TAKE OUT? THE WHOLE SIDE FROM TOP TO BOTTOM OF THE PISTON? This application of heat will likely free things up to allow the extraction of the piston. once the piston is out, welding four stripes of bead down each sleeve will shrink and free them enough (usually to get them moving with a puller puck and 3/4" reddy rod.) WELD THE BEAD ON ON THE INSIDE OF THE SLEEVE. IS THAT CORRECT. I DO HAVE THE SIDE PLATE OFF AND IT LOOKS PRETTY CORRODED IN THERE. NOT SURE HOW TO CLEAN THIS UP WITHOUT DOING DAMAGE?
Home
| Forums
Today's Featured Article -
Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
